repo Radial tires vs repo double bias tires on a 1960 - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    How many points are deducted for repo radial tires vs the point reduction for repo double bias? I know original tires are the preferred but 50 year old tires, are there any available that have been preserved?
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • William C.
    • May 31, 1975
    • 6037
    Re: repo Radial tires vs repo double bias tires on a 1960
    The answer is in the "judging Reference Manual" Section 4, Standard Deduction GUIDELINES. These provide guidelines for minimum deductions for a number of different configurations. A proper Reproduction tire of correct size DIFFERING FROM THE ORIGINAL ONLY in having DOT federally required markings is 10% deduct. Note not all reproductions may be treated equally in this definition, and a search of the archives on this board should provide more information as to "most Correct" for your model year. Current OEM brand current replacement Radial tires 60% deduct (minimum)
    Bill Clupper #618
