62 250hp compression test - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2415
    The following readings were taken: 1- 185 2-195
    3- 190 4-190
    5- 185 6- 180
    7- 180 8- 190
    The old AC-Delco 45-S (4 green stripes) looked good but I put in a new set from Advance Auto Parts (R 45S). No plugs were fouled and no blue smoke. Are the above readings in the proper range?
    • 15706
    Re: 62 250hp compression test
    The shop manual says 160, but actual compression gage readings vary over a wide range depending on the gage. The important result is consistent readings across all cylinders - 20 psi max. variation for a given gage, so it appears your engine is in good internal shape.
    • John F.
      • March 23, 2008
      • 2415
      It was a brand new gauge from O'Riellys. Thanks.
      John
      • Dale S.
        • November 12, 2007
        • 1224
        Yes new, but what brand (manufacturer)? Dale
        • John F.
          • March 23, 2008
          • 2415
          Brand was Innova.
          Jf
