What is zinc? How zinc/phosphorus works
The zinc/phosphorus molecules react in the oil and release phosphorus-containing compounds that make a wear-resisting phosphate glass film on the critical surfaces of contacting engine parts. With most brands, this process also results in phosphorus being released with engine emissions into the catalytic converter, where it can poison the emissions system over time.
Why zinc/phosphorus level in engine oil has changedThe controversy Consumer Solutions
There are high-zinc engine oils available to meet this need. It is important to note,
however, that the entire additive package still needs to be balanced for best performance. For example, engine oil with a high zinc level but low detergent may not perform over a drain interval of 3,000 miles or longer.
Valvoline offers two solutions to the zinc issue
Valvoline Racing VR1: 75% higher zinc than SM engine
oil with a balanced additive package designed to work in
both racing and street-legal applications. This product will
protect older style push-rod and flat tappet engines.
Valvoline provides this product in both multi and mono
viscosity grades: SAE 20W-50 (part vv211), straight SAE
50 (part vv235), SAE 10W-30 (part vv205), SAE 30(part
vv223), SAE 40 (part vv229), and SAE 60 (part vv241)
Rob Clendening & Fran Lockwood
Valvoline, division of Ashland Inc 1-859-357-7000
Lexington KY
Longer-Lasting Zinc/Phosphorus: Valvoline uses an advanced zinc/phosphorus additive that keeps higher levels of phosphorus in the engine oil where it protects the engine, instead of poisoning the catalytic converter. Valvoline is the only brand offering this unique additive across its entire line of passenger car engine oils, including SynPower which is the only synthetic offering this additive. www.valvoline.com
Lexington KY
