Upper Fire Wall Insulation - NCRS Discussion Boards
  • Dave G.
    • February 21, 2007
    • 14
    The upper fire wall isulation on my 64 roadster is gone, if there a source for this fiberglass insulation or would I be better off using something different?
    Dave
  • Dan H.
    • July 31, 1977
    • 1369
    Re: Upper Fire Wall Insulation
    Dave, you can get it from Long Island and others already to glue in. Long Island part sect 12, #49, $37.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Gary C.
      Administrator
      • October 1, 1982
      • 17771
      Dave, if it's a driver and not a car you want to keep to factory specs you might want to consider using another insulation material. I did a test in my '64 on the Convention Road Trip this summer and the article's coming out in the Winter Restorer. Tested 4 different types of insulation for heat reduction. Best of the test was a product named Hush Mat. Also, one of the Texas Chapter guys built a resto rod and he used the spray in bedliner material. Not only cut the heat but reduced sound as well. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
