Hey there -
I had body work and a re-paint done on my '69 L36. Ever since then it has developed a high pitch whistle noise. It comes and goes, but when it comes it is relentless and drives me nuts. It seems to get worse as the rpms get higher and persists through the gears (M22) and will sometimes remain at idle. The pitch of the noise will change as the rps get higher. At idle it will sometimes go away when I tap the gas pedal.
I took it into my mechanic, but it of course didn't do it when he drove it. I read through the archives and there was mention of a clutch plate and a possible vacuum leak. FYI - I replaced the clutch recently at the beginning of the year before the repaint.
Has anyone experienced this problem before? I would GREATLY appreciate any help or advice. It makes for an unhappy driving experience, but more importantly is obviously a symptom that something is not functioning correctly.
Thanks in advance and happy holidays to everyone!
Best,
Rob
Best,
Rob
