Today, I was installing the distributor in the '75 (motor is out of the car, and mated with the transmission on a dolly). A very thin flat washer for the aftermarket distributor hold down disappeared. I can't swear that the washer went in the distributor hole in the block, but being the pessimist that I am, I have to assume that it did. Carefull examination of the hole leads me nowhere. The washer isn't in the lifter gallery, it isn't at the bottom where the oil pump shaft comes up from the pump. and is not stuck to the sides or anywhere around the cam gear. Based on what I see, I don't think that there is any route for the washer to get out of that area, except if it fell into the valley...I spent at least an hour on hands and knees around the motor, hoping that I would find the washer on the floor or otherwise on the motor.....no dice.
I'm afraid that I know the answer, but if I can't see it, do I risk leaving it wherever it is? Hours away from lighting the thing and I get careless and do somthing stupid like this.
Any advice?
Any advice?
