'67 seat back release - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    Neither one of my seats locks or releases using the lever on the 'hockey sticks'. There's still some tension on the lever, but nothing happens when it's moved. Since I'm taking the seat covers off anyway to add headrests, I'll have access to the mechanism. Is there something that usually malfunctions with the release mechanism? How is the problem fixed? Thank you.
  • Bill I.
    • January 28, 2008
    • 554
    Re: '67 seat back release
    Larry, I to am waiting for an answer, as I have the same problem . Bill.
    • Douglas L.
      • August 31, 2003
      • 299
      Check the following:
      * The outside lever attaches to the shaft with a "set" screw. Check to make sure the set screw is not stripped, can be tightened, and will stay tightened.
      * Take the seat back off. Remove the plastic shield that covers the lever mechanism. Check the relay rod to make sure it is connected on both ends.
      * Oil the shaft of the catch mechanism. This is probably the biggest cause of the catch not working. Make sure it moves freely, locks in the closed position, can be released, and springs into the open position.
      * Check the lock mechanism that it is not bent. If the seat back is pushed back while the lock mechansim is closed, it is easy to bend it.
      * Check the alignment of the catch in the seat top with the catch in the seat bottom
      • Gerard F.
        • June 30, 2004
        • 3803
        Larry,
        To add to what Douglas said, check also the position of the catch at the back of the seat bottom. The catch is adjustable side to side by loosening the screws which hold the catch in place.
        Usually the problem with the seat bottom catch is that the seat back won't stay locked back. From what you describe, the problem is probably with the seat back mechanism.
        Hope this helps,
        Jerry Fuccillo
        • Kirk M.
          • June 30, 2006
          • 1036
          I agree with Jerry. Neither of mine worked properly until I adjusted the CATCH mechanism. In other words, the latches weren't getting "pushed" back into the lock position when the seat was pushed back. Once I figured that out and got it adjusted correctly, all it took was some lube and working the latch back a forth a bit to loosen it up and bingo - both seats now work.
          • Larry S.
            • March 11, 2007
            • 457
            Thank you everyone for your usual excellent help!
            • Tom D.
              • September 30, 1981
              • 2126
              Re: '67 seat back release (lever = 3903570)
              Today I noticed the following:
              Release Knob (or lever) on the side of each seat at the "hockey stick" has part number 3903570 cast into the backside.
              Original 1967 Knob has a significantly larger "set-screw" than does the service part! (Service part was purchased in 1970's.)
              Service part (3903570 on the box) includes the smaller set-screw, also has 3903570 cast into the backside.
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Ray G.
                • May 31, 1986
                • 1187
                Hello Tom;
                Is it possible the set screws were drilled and tapped a larger size on the originals?
                Set screws slotted or allen?
                I hope you dance
                • Tom D.
                  • 2126
                  Both orig. and service set screws are slotted. I believe there is no way (both) originals would have been drilled & tapped.
                  1. They look better than the service part.
                  2. The pass. seat was hardly used - Still has orig. vinyl and no rust on the tracks, despite early driving in Western NY.
                  3. The car has low miles.
                  4. I know all owners, except the original (first) one.
                  I will post photos when time permits.
                  Tom
                  Michigan Chapter
                  Tom Dingman
                  • Ray G.
                    • May 31, 1986
                    • 1187
                    Tom
                    Hello Tom;
                    Do you think this info should find its way into the '67 JG.
                    Is there a significant enough difference for judges to be aware.
                    Thanks for your work.
                    Ray
                    I hope you dance
                    • Tom D.
                      • 2126
                      I suppose... I guess I have no comment on the judging guide... showing this particular detail.
                      In my photo, the lever on the left is the one that came in the box shown. It was stored improperly, so there is rust on the set screw. It was ordered by Hartway Motors in Medina, NY and sold to me as NOS 25 years ago. I am sure it looked a lot better on the day I bought it. I can't remember if I was the one who ordered it, but they didn't have many other Corvette customers (until recent years.)
                      The other two were on my un-restored original black vinyl seats since I acquired the 1967 in June of 1976. See above for my comments on original status.
                      I didn't notice the difference in the size of the set screws until December, 2009.
                      Michigan Chapter
                      Tom Dingman
                      • Ray G.
                        • May 31, 1986
                        • 1187
                        Hello Tom;
                        Thanks for posting.
                        Your efforts are appreciated.
                        Ray
                        I hope you dance
                        • Brooks G.
                          • November 30, 1978
                          • 286
                          Larry, till now I was not aware that some of the handles for the seat back locks had larger set screws. The mechanism on my '67 did not work when I bought the car. When I took the seat apart I found the shaft that the lever attaches to had broken. It looked to me like a combination of rust and a groove in the shaft which I believe contributed to the weakness. At the time you could not get a replacement part so I made one out of stainless steel. I was doing machine work at the time. At the time I had made tooling to mass produce these parts. Years ago I showed Al Knoch what I had made and he told me that he wasn't interested as he had enough junk seats to last him the rest of his life. That took the air out of my sails but at least I was able to fix my car. I think that part is now available as a reproduction. Not out of stainless steel though. My Corvette Central Catalogue shows it to be called a crank with p/n 482043 at $16.50 each. I hope this helps you. Brooks Glover (2141)
                          • Tom D.
                            • 2126
                            There is another discussion about the used of the two different set screw sizes, in this forum:
                            It's more than 10 years later now, I am still thinking the smaller set screw (8-32 instead of 1/4"-28) was a NOS (service only) version. Like a lot of OEM vs. NOS changes, I wonder why? Perhaps the smaller set screw was cheaper.
                            Michigan Chapter
                            Tom Dingman
                            • Tony S.
                              • July 15, 2009
                              • 39
                              Here are 2 photos of the Lever from a 1967 Jan13 Build. hope this helps.
