69 L36 PCV hose and spring clamp. - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Does anyone know how long this hose should be? I seem to remember it having two separate applications so I'm not sure if I should leave it at 24" or cut it a certain length.
    Also, what color should the spring clamp be on the PCV end?
    Does the carb end get a clamp as well?
  • Greg L.
    • March 1, 2006
    • 2291
    Re: 69 L36 PCV hose and spring clamp.
    Well near as I can tell the carb end of it doesn't get a clamp but I still don't know what color the clamp on the PCV end should be...anyone?
    It's also WAY too long as it is so I do have to cut it. Does anyone know how long it should be? Should it go through the lifting bracket...over it...or around it?
      • 43248
      Greg-----
      The AIM shows clamps at both the the carb end and the PCV valve end. However, I can tell you that my 1969 small block never originally had a clamp at the PCV valve end. I'm sure about that. As I recall, the color of the clamp was black. I still have it, but it's not where I can get at it right now.
      • Greg L.
        • March 1, 2006
        • 2291
        Ya you're right Joe. I looked at my AIM again and I see that it does show a clamp at the carb end.
        I still need to figure out how long it should be. If anyone has a blueprint it is p/n 3901839. A pic of an original hose installed on the engine would be just as good too if anyone has one.
