'69 L-68 expansion tank usage? - NCRS Discussion Boards
  • Warren F.
    • December 1, 1987
    • 1516
    I helped a friend purchase an early '69 L-68 coupe. This car is vin #2554. Before buying the car we both looked it over pretty well. There were issues to deal with, but overall a decent car. We couldn't see any signs of body damage/repair areas. Does this car call for an expansion tank? This car is very low optioned, only headrests, four speed, and 427/400hp engine option.
    I don't have the '68, 69 TIM as I usually deal in '70 to '72 years.
  • Dick W.
    • 10483
    Re: '69 L-68 expansion tank usage?
    Unless it has A/C tank not required.
    Dick Whittington
    • Dick W.
      • 10483
      Dick Whittington
        • 43219
        Warren-----
        ALL 1969 big blocks utilized a radiator supply tank. Those with C-60 utilized a brass, cylindrical tank. All others used the familiar aluminum tank used for many 68-72 small blocks with aluminum radiator.
        The same thing was true for all 70-72 big blocks, too.
          • 43219
          Warren-----
          • Warren F.
            • December 1, 1987
            • 1516
            Dick & Joe,
            Conflicting information...huh. This car's inner fender doesn't show any signs of ever having the mounting bracket riveted for the tank mounting. It does have a radiator with a cap, although the cap is aftermarket.
            Bizzoco's 1969 Stingray Guide Book lists some 400hp cars without AC as having a surge tank, and of course the AC cars with the brass style tank. But it also lists some without AC and no mention of a tank.
            I think Joe may be correct, as Bizzoco's book shows vin #00007 as 400hp, no AC, and surge tank.
            • Warren F.
              • December 1, 1987
              • 1516
              Dick & Joe,
                • 43219
                Warren------
                No 1969 big block ever used a radiator with an integral cap---none whatsoever. There did not even exist such a radiator for a Corvette big block application at the time. The only 1969's that didn't use a radiator supply tank were small blocks with M-40 and/or C-60 and some L-46. These used a copper/brass radiator with a 26" core width and with an integral filler cap. I have no information that this radiator was ever installed on a big block. In fact, it couldn't have been used because there would have been no molded radiator hoses to fit the small block copper brass radiator used with a big block.
                1973 was the first year that big blocks used a radiator with an integral cap and no external supply tank was used (although a coolant recovery system was used for the first time in a Corvette). Sometimes, these 1973-E76 radiators find their way onto earlier cars. However, if this car has no evidence of a supply tank ever having been mounted, then it's an original small block car that was converted to big block without the radiator being changed or it's a car that has the 73-E76 radiator and someone has replaced the right side inner fender.
                  • 43219
                  Warren------
                    • 43219
                    Addendum
                    By the way, when the 73-E76 radiator is used in a 1969-72 big block application, the 1969-72 big block radiator hoses will fit fine.
                      • 43219
                      Addendum
                      • Warren F.
                        • December 1, 1987
                        • 1516
                        Re: Addendum
                        Thanks Joe, we'll scrutinize this car very closely to see what all has been altered. Obviously something a miss.
                        • Warren F.
                          • December 1, 1987
                          • 1516
                          Re: Addendum
                          • Michael B.
                            • June 18, 2007
                            • 400
                            Re: Addendum
                            My Oct 03, 1968 build date had one. ##3676
                            • Warren F.
                              • December 1, 1987
                              • 1516
                              Re: Addendum
                              Mike,
                              Thanks for the reply and the picture. I'll show this to my friend with vin# 2554.
