Re: 72LT1 replaced turn signal swtich now trans locked
Here is the address for the paper on the GM Steering Column/Transmission Shift Interlock System. It is all you will ever want to know.
BTW, there is not a lot of cable adjustment available by moving the plate (identified as M in the Installation Diagram) in the paper. Also, you still want the steering column to be aligned correctly to the flexible coupling assembly on the steering gear.
Jim
Jim
