67/427/400 Factory Side Pipe Heat Riser Question - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 621
    When I replaced the heat riser valve in my 67 BB (The weight had shearded off), the through-hole measured just under 2" (1.92). It was replaced with a correct NOS (3887034), but I never measured the through-hole diameter.
    Hopefully this is not a dumb question, but is the flange, casting and bolt pattern of the 2" and 2-1/2" heat riser the same with the only difference being the through-hole and flapper?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • 43286
    Thomas-----
    No, the flange, casting, and bolt pattern of the 2" and 2-1/2" are not the same.
    • Thomas S.
      • February 7, 2016
      • 621
      Thanks for the reply. That's what I thought. The only other question is why is the thru-hole in the heat riser flange only 2" in diameter instead of 2-1/2"?
      • Mark E.
        • April 1, 1993
        • 4609
        Making sense why GM does something can be exasperating. But I believe the diameter of your sidepipe mufflers is less than 2" (1 7/8" ?). So the heat riser isn’t the only restriction.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Thomas S.
          • February 7, 2016
          • 621
          That’s what I figured. A 2-1/2 “ exhaust system heat riser has a 2” thru-hole.
