When I replaced the heat riser valve in my 67 BB (The weight had shearded off), the through-hole measured just under 2" (1.92). It was replaced with a correct NOS (3887034), but I never measured the through-hole diameter.
Hopefully this is not a dumb question, but is the flange, casting and bolt pattern of the 2" and 2-1/2" heat riser the same with the only difference being the through-hole and flapper?
