Tri-power fuel lines - NCRS Discussion Boards
  • Hebert K.
    • September 5, 2011
    • 33
    Getting ready to install the fuel lines on my 67 L71.
    After reading all of the leaking problems others have had, should I install flair gaskets on the lines or try installing the lines first and see if they seal?
    The lines are steel, not stainless.
    Thanks, Herb
    • 15706
    For new flare fittings tighten-loosen at least THREE times before finally tightening and pressurizing to check for leaks.
    You can do the same for used pieces, especially if they are not the original mating pairs.
    I think the "gaskets" are a last resort.
    Absolutely use a five-sides "tubing wrench" to avoid buggering up the B-nuts.
      • 15616
      I would add: Based on my experience that five-sided wrench is no place to cheap out. A quality tubing wrench is imperative for fuel and brake lines. There is a difference between big box store wrenches and professional quality wrenches.
      • Mark F.
        • July 31, 1998
        • 1571
        As a tripower owner myself, I totally agree with the wrench issue...
        I would also add one of the funniest Terry phrases he sent to me (and probably others)...
        "the only thing worse than one Holley - is three Holleys" LOL
        thx,
        Mark
        • Leif A.
          • August 31, 1997
          • 3644
          Our prized Corvettes deserve only the very best!!
          Leif
          • Hebert K.
            • September 5, 2011
            • 33
            Thanks Duke, I will try that.
            I do have a set of Matco tubing wrenches I will use.
            I still do not have a definitive answer on if I can use the 3/4 groove distributor in my engine (427 - A97 casting date)
            If any member knows, please let me know.
            Thanks, Herb
              • 15706
              I recall John Hinckley addressed this issue long ago, and he said it was okay. Maybe someone else can confirm.
              • Mark F.
                • July 31, 1998
                • 1571
                Originally posted by Hebert Kranz (53796)
                ...I still do not have a definitive answer on if I can use the 3/4 groove distributor in my engine (427 - A97 casting date) If any member knows, please let me know. Thanks, Herb
                Herb,
                Go to Advanced Search and type this in to the first box exactly as shown (quotes and font case)
                "groove" AND "distributor"
                then in the member box directly below it, type in:
                John Hinckley...a popup window will show his name and membership number...click on it and then:
                click the search button.
                i got 4 thread hits when I did it...
                I don't know which one you need, but you can peruse them at you leisure...
                Please remember all our Veterans and their families this weekend - living and passed .
                The freedoms we enjoy today have been bought with their sacrifices
                thx,
                Mark
                • Tim G.
                  • March 1, 1990
                  • 1389
                  I'll probably open a can of worms, so for what it's worth, here's how I solved the problem of leaky tri-power fuel lines.
                  The tri-power set up has many connections and this Viton O ring seats perfectly in the carb and blocks (and fuel pump). I use this O ring on the connections from the fuel pump up. Some critizize using this method and I did not originate the idea. These O rings are indestructible and no need to "crank" the lines down. Also, no need to mutilate the lines when you remove them.
                  Again, not my idea and others with tri-power cars told me about it. Maybe it's against the "rules" and fire away at why it's not a good idea, but these O rings are in every one of my Corvettes. Small blocks use a smaller O ring.
                  • Hebert K.
                    • September 5, 2011
                    • 33
                    Can someone please explain,
                    "the distributor housing with the partial oil annulus can reduce or interrupt oil feed to the lifter galleries unless it's installed just right"
                    I thought Chevy distributors were installed one way, with the vacuum advance canister located on the passenger side of the engine pointing roughly to the front right side of the engine.
                    • Ty T.
                      • June 30, 2004
                      • 73
                      I rebuilt the carbs on my 69 3 years ago. Could not get the lines to stop dripping. I finally resorted to copper flare gaskets. I think I got them from Grainger. Worked like a charm and not one drip since.
