Fuel injection - NCRS Discussion Boards
Fuel injection
  • John G.
    • January 1, 2004
    • 238
    Fuel injection
    FI air filter. What is the length and diameter of the cannister?
  • Don H.
    • December 1, 1981
    • 1491
    Your year?
    • John G.
      • January 1, 2004
      • 238
      Car is 1964
      • Jim L.
        • September 30, 1979
        • 1816
        Are you wanting these dimensions in order to find/identify a low cost replacement filtering element?
        • John G.
          • January 1, 2004
          • 238
          The idea is to get a sense of the available space between the cannister and engine to see if a mini alternator can be used.
          An AC compressor fills the right side void.
            • December 1, 2005
            • 195
            John,
            A/C was not a factory available option for a Fuelie. That said, Don Heckenberg has a ‘65 coupe with A/C and fuel injection so he might be a good source for addressing your question. Also, there are different mounting arrangements for small block alternators, including a low mount bracket that might work. One drawback might be the availability of drilled/tapped holes where you need them on these older blocks.
            • Michael G.
              • November 12, 2008
              • 2157
              I added air conditioning to a 63 Fuelie. Used a Vintage Air serpentine system that placed the alternator in front of driver side head, thus allowing the air cleaner to fit. I’ll find a pic and post it.
              Mike
              1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
              1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
