1967 Small Block Hood - NCRS Discussion Boards
  • Kevin G.
    • February 1, 2005
    • 1076
    All, Happy Thanksgiving to you and yours!
    May I impose on you folks for your expert opinion? I'm looking at a hood offered for sale for my 67. My question is, for my 106xx mid production car, would there be any "imprint" or evidence of the locating holes where the hood emblem had access on the underside on the '66 hoods. Or is that underside smooth no holes or markings? Hope the question is clear....tough without the use of photos
    [/COLOR]
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: 1967 Small Block Hood
    Holes or no holes or filled in holes is the question?
    This picture shows the access holes.
    • Keith B.
      • September 15, 2014
      • 1591
      Yes all 67 SB hoods have the emblem hole access holes
      • John D.
        • June 30, 1991
        • 875
        My early no hit 67 built prior to the strike appears to have filled emblem holes.
        • Mark M.
          • October 21, 2008
          • 340
          Kevin, I have access here to what seems to be a 67 production line 327 hood. It has the flat steel rivets , not the aluminum pop rivets. The reinforcement panel has the 3 round and 1 oval holes for installing the emblem nuts. The top hood panel is not drilled but has small nubs at each location where it would need to be drilled if an emblem was used as a 66 has. The nubs are round ,a little less than 1/8" round and protrude about 1/16"
          • Kevin G.
            • February 1, 2005
            • 1076
            Thank all you boys for the replies but......the confusion continues.
            • Bill M.
              • 1328
              Kev are you referring to the holes that would have to be drilled to instal the emblem on a 66 hood ? I have a no hit 18,000 car with filled in holes for s 66.hood I was told that there is no way 66 hoods were used on 67 cars.
              • Kevin G.
                • February 1, 2005
                • 1076
                Hi Bill, Yes, i am referring to those access holes. The going back and forth with this question, leaving me without a diviative answer had me walk away from the hood I was looking at....The hood offered had no holes, no trace of holes, a smooth reinforcement. I'll wait to buy after a bit more education.
                If you post a picture it would a terrific help to me?
                TIA
                • Gary B.
                  • February 1, 1997
                  • 7054
                  Kevin,
                  Gary
                  • Mark M.
                    • October 21, 2008
                    • 340
                    Kevin, I don't know if any 67 327 hood came without the access holes. A very late AO Smith 67 I've seen had them. If they were using up left over 66 under panels because 67 didn't need them with holes, the 67 survivor 200xx I saw probably wouldn't have them. If the hood you looked at had no holes in the underside for emblem nuts, it may have been a 65 hood. If you are looking for a correct 67 327 hood, the fiberglass color is black, 65 fiberglass was white or light gray. The front vertical edge of the bottom hood panel on all c2 cars, often had very little primer, body paint and black out over spray on them so fiberglass color can be seen. This can be seen through the grille opening with the hood closed. Also production line hoods should have steel flat type rivets about a 1/2" head holding the hardware plates on.
                    • Mark M.
                      • October 21, 2008
                      • 340
                      IMG_1431.jpgThis is a 67 200xx AO Smith car 11k miles never hit.
