67 Gravity brake bleed - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 803
    I recently gravity bled my brakes on my 67, primarily just to flush out old fluid. I am glad I did this apparently I had a little air in the system because I have a much better pedal now than before. I thought my pedal was fine before but much better now. The fluid that I drained out looked like tea was pretty bad.
  • Larry E.
    • 1692
    Re: 67 Gravity brake bleed
    Lawrence: Thinking of doing the same to my(C2)- 66 Convertible. Brake fluid is DOT#5. Thinking I also have a
    little air in the system. CAR HAS KNOCK OFF WHEELS. Question for anybody> Can I gravity brake bleed the
    system WITHOUT TAKING THE WHEELS OFF?? Need advice please>Larry
    Larry
    LT1 in a 1LE -- One of 134
    • Lawrence S.
      • April 1, 1993
      • 803
      You have to remove the wheels to get to the bleeders. I used Dot 3 fluid in my car.
      • Leif A.
        • August 31, 1997
        • 3645
        No you can't. To access the bleeders, the wheels must be removed. Also, don't forget there are two bleeders on each rear caliper...an inner and an outer.
        Leif
        • Larry E.
          • 1692
          Leif/Lawrence> Thanks for the input; Larry
          Larry
          • Bill M.
            • 1328
            I gravity bleed a little fluid out of each caliper every couple of years.
            • Pat H.
              • December 1, 1996
              • 420
              This procedure also would on C-1's I do it every couple of years. I found that the pedal is a bit firmer.
