Adjusting C1 Drum Brakes - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    I first adjusted my '62 brakes per the ST-12. That didn't work well, so now I'm adjusting them by trial. That is, I make an adjustment and then take the car out and brake hard a few times. Then readjust. So far, I have eliminated the pull the one side. Right now I'm working on the right rear locking up. I'll be back at that tomorrow. But what wheel(s) should lock first? In a perfect world, all 4 of them would lock at the same time. But if I have to live with one locking first, which one should it be?
  • Jim L.
    • September 30, 1979
    • 1816
    Re: Adjusting C1 Drum Brakes
    You always want the fronts to lock up first. If the rears lock up first, as counter intuitive as it may seem, you can lose directional control.
    • Terry D.
      • May 31, 1987
      • 2696
      I would want to k now why the St-12 procedure didn't work.
      • Christopher R.
        • March 31, 1975
        • 1599
        A combination of a few factors, most of them involving operator (That'd be me - an inexpert mechanic.) error. I could never be certain what "light uniform drag" was and what "12 notches" of the star wheel was. I found the road test, slight adjustment, road test again method the easiest and most certain. I don't have a lift and my garage is tiny.
        • Terry D.
          • May 31, 1987
          • 2696
          Agree with Jim, as the fronts do most of the braking you would want them to lock up first
