Source for flat capped u-joints - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Looking for a source for flat capped u-joints , like the original equipment was. judging manuals call for these on rear half shafts and driveshaft.
  • Brian M.
    • November 1, 1994
    • 128
    Re: Source for flat capped u-joints
    Bill,
    I was able to source flat cap universal joints w/o grease fittings for the half shafts from Paragon (#5728). I called them and had the customer service person pull them to confirm.
    I was unable to get flat cap universal joints w/o grease fittings for the drive shafts, so I settled for the Paragon (#5724). The customer service person did look.
    See you in June!
    Brian McIntyre
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 990
      William, we really can't see the U-joints in the drive shaft, so just get the U-joints for the half shafts. There are 16 caps in the half shafts, so it is a meaningful part of the half shaft judging (configuration). Stepped caps get a 1-point deduction from the 65 and 66 chassis judges. I can't speak for the 63, 64 or 67 teams. Hope that helps. Tony
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 886
        Let's do the math. 5 points for Driveshaft and Half Shaft assemblies. How are we splitting up the points between 2 1/2 shafts, 2 Yokes, 1 Drive shaft. 6 UJoints, 52 pieces of hardware(nuts, straps, locks)?
        • Tony S.
          • April 30, 1981
          • 990
          1 point Joe. Some features have greater weight than others. It is not just 52 divided by whatever. You have to weigh the importance of the components. U-Joints aren't just "hardware". There are 16 caps and make up a pretty major part of the line item.
          Let me make my point by this example: how many components in a 5-point lower A-arm? You have the large steel A-arm itself, the cross shaft, the two bushings, the ball joint, the cotter pin, the nut and washer on top of the ball joint, the zerk, the two rivets, the rubber bumper, the two bolts that attach the bumper to the A-arm. Did I miss anything? That's about 12 items. So each of these represents 1 of 12. The ball joint rivets should be natural, right? If the two rivets are painted black, that is only a minor finish deviation but too small to deduct for a 1-point finish deduction on a 5-point item. Right? Change the example: let's say that everything is typical factory, but the steel A-arm itself is unpainted (should be gloss black). The steel A-arm itself is still only 1/12 of the line item by your analysis. But if the steel A-arm itself is unpainted, then the proper deduction is 1 for finish because that one item is the major component even though it is 1/12 of the entire assembly by your math analysis.
          The point is this: sometimes you have to weigh the components by importance. It isn't always just add up the components and divide. It often is, but not always.
          • Joseph S.
            • March 1, 1985
            • 886
            We've taken this thread off the intended path. The original thread was for a source for flat caps. I was just trying to show Bill that there is not that much weight given to "just the Caps" on the entire 1/2 shaft assembly. Most judges will just write him a note and let him know about the proper caps.
            • Harry S.
              • July 31, 2002
              • 5330
              Yep, write a note, slash the box and move along!
              • William B.
                • April 30, 1975
                • 942
                Thanks everyone, calling Paragon tomorrow. my 66 judged in 2017 regional never received a deduct for u-joints, my 65 judged last year regional received the 1 point deduction, both have stepped u-joints.
                Restoring a 67 now and want to be more correct.
                • Joseph S.
                  • March 1, 1985
                  • 886
                  Tony, I feel I need to correct your math. If you take a 20% Configuration for the U joints, by taking a 1 point deduction you are placing 5 points value on the UJoints alone and 0 points value on the rest of what is there. You need to assign a value to the Drive shaft & Yokes, a value to the 1/2 shafts and a value to the 52 Hardware items. The UJoints alone can not be valued at 5 points.
                  • Stewart L.
                    • March 1, 1980
                    • 355
                    Mike at Americas Finest is the manufacturer/importer and the other vendors source them from him.
                    • Joseph T.
                      • March 1, 1986
                      • 169
                      William
                      The 1967 Judging team has discussed the "U-joint flat cap" subject on numerous occasions and felt that it doesn't warrant a deduction with only 5 points assigned to both half shafts and drive shaft. We will make a note about them and move on. Good luck with your restoration
                      • Joseph S.
                        • March 1, 1985
                        • 886
                        Hmmm! I think I'll stay with a Spicer or MOOG part!
                        • Joseph S.
                          • March 1, 1985
                          • 886
                          Tony, We shouldn't be breaking an A Arm into components. The rule is that a component should be assessed as it is retrieved from the parts shelf. Since the A Arm is assembled and painted as a unit the entire A Arm should have a value of 2.5 points each side. This has been and will again be discussed during the CDCIF class at the Judges Training Retreat.
                          • Tim L.
                            Infrequent User
                            • September 4, 2013
                            • 12
                            I bought all the flat cap u joints that Paragon had about 6 months ago. I have 4 that I will sell if you can't find them, PM me.
                            • Tony S.
                              • April 30, 1981
                              • 990
                              Joe: I suspect I will be participating as an instructor there in some capacity per our mutual friend.
