Delco Stereo Radio, Speakers in Dash Replacemnt - NCRS Discussion Boards
  • George H.
    • March 9, 2017
    • 180
    On my '73, I need to replace the original headlight switch. In doing that, the dash needs to be undone/removed to access the switch. Since I will be doing that, I should probably replace the original pair of radio speakers that don't sound all that good. Therefore, I will need to buy replacement speakers that are 4"x6", 8 ohm, about 40 watts, and like 92db sensitivity. Any recommendations as to the best Brand and where can I buy them? Looking for quality good sounding in-dash speakers.
    gator943
    • 43247
    Re: Delco Stereo Radio, Speakers in Dash Replacemnt
    gator943
    George------
    The original speakers are 10 OHM. You can get by using 8 OHM speakers, though. As a matter of fact, to get a really high quality speaker you will need to go 8 OHM as there are no high quality 10 OHM speakers I know of. However, to be honest, if it were me, I'd seek out reproduction 10 OHM speakers and live with their sound quality.
      • 11668
      Here are the reproduction 10-ohm speakers. Call them to buy two; otherwise, most catalog companies also stock them.
      https://www.smelectrotech.com/product/4-x-6-oval-high-performance-single-/46?cp=true&sa=false&sbp=false&q=false&category_id= 4
      The least expensive and probably best option is to have your originals reconed. Blackie's in Grand Rapids near me does it for many people I know (http://www.blackiestv.com) at around $25 per speaker. You may have a local source that would do it as well.
