69 427 Alternator Belt - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 800
    Hi Guys,
    I bought a Quanta alternator belt for my 69 L71 non PS and it wont fit over the alternator pulley. Full 1/2" short. The belt does not recess nicely in the pulley like I am use to seeing. Just curious if others have had this same problem with Quanta belts. I will call Quanta today and get the proper specs for the belt. I have had good luck with Quanta in the past. First mishap.
    Let me know if others have had this issue.
    Lawrence
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: 69 427 Alternator Belt
    Lawrence,
    I also had a fit problem on a 1967 L71 non-PS alternator, but it turned out I had the wrong alternator pulley. HERE
    What is your Quanta belt part#? 3882814 ?
    Rich
    • Lawrence S.
      • April 1, 1993
      • 800
      Rich,
      No, My part number is 3940991A.
      I will check out that thread about the pulley, and check the Judging Manual.
      L
      • Chris H.
        • April 1, 2000
        • 837
        • Lawrence S.
          • April 1, 1993
          • 800
          • Lawrence S.
            • April 1, 1993
            • 800
            Chris, is your car unrestored?
            • Chris H.
              • April 1, 2000
              • 837
              Lawrence, yes unrestored. 14k miles when I purchased it.
              • Lawrence S.
                • April 1, 1993
                • 800
                Very nice. I may ping you with a PM as I work through my 27K mile L71. It too unrestored but has had some stuff tinkered with which I am unwinding.
                • Lawrence S.
                  • April 1, 1993
                  • 800
                  Rich, I confirmed with Quanta that I have the correct belt. Will check my pulley next time I am back in Clt.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11323
                    Yes I see now at the Quanta site that the '69 L71 belt(3940991) differs from the '66/67 version(3882814). Strange. I wonder what changed to require a different belt?
                    Edit- So it's not the pulley that changed. The 3829387 is for 1966 to 1969. Maybe the alternator itself or the brackets?
                    Rich
                    • Lawrence S.
                      • April 1, 1993
                      • 800
                      Rich, The alternator is the one that I assume was installed when new? Dated to the car, correct TI alternator for an early 69 car. I checked my JM to confirm the bracket is correct, and it seems as if it is correct. I need to confirm the pulley has not been changed. Would be surprising since the alternator is the correct one, but who knows. Will update the thread when I am back with the car.
                      I may have to do what Chris did and just loosen the alternator bracket enough to get a little more movement in the alternator to connect the belt.
                      I have gone ahead and finished installing the A.I.R. including the belt so I can test the A.I.R system.
