Rebuild question-C2 parking brake - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 215
    I have my shiny new SS parts for my rebuild-my question is: how do I properly position the actuator? Is it necessary to remove the clip at the joint? not sure how to do that -Is there a tool for that? Input appreciated.IMG_0073.jpg
  • Gary R.
    • April 1, 1989
    • 1798
    Re: Rebuild question-C2 parking brake
    You have to slip it in place, as you know, but you shouldn't have to remove the clip. It is tricky to do with the axle in place. I suggest you test fit the parts before installing. Check the hold down pin heads, they should be sharp like an arrowhead. You may find the shoes hit the rotor hat I machine the star wheels now with every kit I get.
    • Owen L.
      • September 30, 1991
      • 868
      What machining do you do to the star wheels?
