Staples - NCRS Discussion Boards
Staples
  • Gary B.
    • February 1, 1997
    • 7018
    Staples
    Does anyone know of a source for plain steel staples, e.g. for A-arm flaps? It seems like all the vendors I checked offer stainless or magnetic stainless. I want neither. I want old fashion, plain steel that will quickly develop an aged patina.
    Gary
    Last edited by Gary B.; April 9, 2021, 09:56 AM. Reason: Meant to say magnetic, not non-magnetic
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Staples
    If you can't find them, they are easy to make.
    • James G.
      • August 22, 2018
      • 800
      Re: Staples
      I found it easier to make them from tig rods - a piece of scotch brite will knock the light copper plate off, then use a pair of pliars with the correct width jaws. Bend one leg with the pliars grab the width bend the other side of the rod 90 deg - clip off staple - start over.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Don L.
        • August 31, 2005
        • 1005
        Don Lowe
        NCRS #44382
        Carolinas Chapter
          • December 1, 2005
          • 185
          Re: Staples
          Gary,
          Refer to the similar thread below "C2 Dust Shield Staples" that I submitted last year. They are pretty easy to make. Repros are typically stainless steel and will not pass judging. I got some from Paragon and never used them.
          • Gary B.
            • February 1, 1997
            • 7018
            Re: Staples
            Terry,
            I wouldn’t be surprised if the magnetic stainless staples that some vendors sell will indeed pass judging. But I want staples that will develop a patina that the stainless will not develop.
            Gary
            Last edited by Gary B.; April 9, 2021, 09:54 AM. Reason: Meant to say magnetic, not non-magnetic
            • Don L.
              • August 31, 2005
              • 1005
              Re: Staples
              Originally posted by Terry McCarthy (21187)
              Gary,
              I would agree that stainless staples are not typical for production, however, I wouldn't say they won't pass judging.
              BTW, I should have mentioned how the SS wire I used was magnetic. When I was working, I had great access to lots of different kinds of wire. Not no more...
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Gary J.
                • April 1, 1980
                • 1241
                Re: Staples
                In all honesty a judge should not be using a magnet , just saying....
                • Gary B.
                  • February 1, 1997
                  • 7018
                  Re: Staples
                  Originally posted by Gary Jaynes (3503)
                  In all honesty a judge should not be using a magnet 🧲, just saying....
                  Gary,
                  True, But some still do. The newer version of magnetic stainless staples will pass the magnet test, as shown by the example on the Long Island Corvette website.
                  Gary
                    • 6942
                    Re: Staples
                    Gary, I just took a pocket or small flat blade screwdriver an bent them back, and reused the old ones.I had zero problems used a 1/16 in drill and place the flap in place where you want it and used the old holes.
                    • Gary B.
                      • February 1, 1997
                      • 7018
                      Re: Staples
                      Edward,
                      I have some of my original staples currently soaking in Evapo-Rust to see how they will come out.
                      Gary
