66 body shim question - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 324
    Hi, where all the body shims used in 66 models the square ones or where some slotted, in the replacement body mount kits they show both
    thank Bob
  • Tom K.
    • February 26, 2008
    • 167
    • Page C.
      • February 1, 1979
      • 802
      Re: 66 body shim question
      The only slotted body mount shims that I can think of are the shims used at the front frame horns. These shims are between the frame horns and radiator core support and are welded to the frame horns.
      • Russ S.
        • April 30, 1982
        • 2163
        Also used between the radiator support and the inner fenders
        • Stewart L.
          • March 1, 1980
          • 356
          Also, count the number of shims you need and make sure there is enough in your kit for your car. Do this with enough advance time to get more shims if you need them.
