Was antenna chromed - NCRS Discussion Boards
Was antenna chromed
  • Mark A.
    • February 1, 1996
    • 299
    Was antenna chromed
    On my 69 coupe, I have the original antenna. It has no plating on the mast, but appears to have peeling chrome on the base. Was the entire antenna chromed originally? Mark
    • 43219
    Re: Was antenna chromed
    Mark------
    No, it was not.
    • Mark A.
      • February 1, 1996
      • 299
      Joe. They must be stainless steel then? Mark
        • 43219
        Mark------
        I believe stainless is what they are.
        • Ron G.
          • December 1, 1984
          • 865
          Not sure, but the ball on top and the base is chrome. Like I said I believe.
          "SOLID LIFTERS MATTER"
            • 43219
            Ron------
            I believe the ball end is also stainless steel but it does appear to be chromed. In fact, it's even a better stainless than the staff inasmuch as the staff is mildly magnetic while the ball is non-magnetic. Of course, the ball could be chromed non-ferrous metal but I highly doubt that.
            The base and nut are definitely chromed steel.
            • Jeffrey S.
              • May 31, 1988
              • 1882
              [QUOTE=Joe Lucia (12484);
              For some years I was making reproduction antennas that were matched exactly to 69 up fixed mast antennas and have disassembled and examined the base metals of many original (but wrecked) antennas and deplated the individual parts and here is what I found. The base is chrome plated steel. It was pressed onto the shaft which was stainless. The ball was chrome plated brass and was also pressed onto the shaft.
              Jeff
