1967 Factory Paint Primer - NCRS Discussion Boards
  • Ronald W.
    Infrequent User
    • January 1, 1992
    • 3
    What was the factory paint primer for 1967 Corvettes ?&nbsp; I am restoring a 67 St. Louis built coupe that I have owned for 43 years. Original primer appears to be red oxide.&nbsp; Or, should it be gray (light or dark) ?&nbsp; Finish paint was Marina Blue.<br>Ron W.
  • Mark F.
    • July 31, 1998
    • 1571
    Re: 1967 Factory Paint Primer
    Ron,
    Per John Hinckley's National Convention presentation beginning on page 3 "Paint Shop" and continuing on the middle of page 4...first primer coat is red; 2nd coat is gray...see link for entire presentation below - hope this helps. thx, Mark
    "Spray quick-flash lacquer-based red oxide primer coat, flash for one job length, spray lacquer-based gray primer coat (including parts on body floor)
    thx,
    Mark
    • Domenic T.
      • January 29, 2010
      • 2452
      When I stripped the acrylic laquer with a razor blade al I found was the red oxide which is laquer based primer.
      When that was the primer of the day I used it, but with the epoxy primers we have today I would never go back to the old as it shrinks over time.
      Different color primers change the shade of the paint top coat. I have used a tinter in epoxy primer and that worked.
      I went to the paint shop in 1960 to pick out a red for my car. I was torn between 2 reds. Then I wrote the code # down and noticed they were the same #. I asked the counter guy about that and I got a new lesson in painting. He said that one red used red oxide and the other dark gray.
      Dom
      • Frank D.
        • December 27, 2007
        • 2703
        The fellow that painted my split window (who also painted one of the rare '67 L-88 cars) used red oxide (back in 2018)
        The final top coat is single stage Riverside Red
        • Larry M.
          • January 1, 1992
          • 2701
          The gray was a "guide coat" and was generally sanded away to reveal any high and low spots (in the red main primer) that needed correction prior to final painting.
          Larry
          PS: If you are as talented as Frankie's painter, a guide coat to reveal imperfections is not required.
