Bolt torques -- '65 and '69 manual steering gear side cover - NCRS Discussion Boards
  • Wayne M.
    • February 29, 1980
    • 6414
    What are the torque values for the 3 side cover bolts on a '65 Saginaw steering gear; same for a '69 [with the aluminum cover]. Ditto for the lash adjuster screw lock nut (the one in the middle top of the cover).
    I've got a dozen manuals and I can't find those torques specified anywhere. The driver's manuals say to check every 36,000 miles (remove forward bolt and "fill", until gear oil/grease is seen at the outboard cover bolt).
