door lock cylinder - NCRS Discussion Boards
door lock cylinder
  • Mel S.
    • August 31, 1992
    • 264
    door lock cylinder
    When I took my door lock cylinder out, I left the rod in the lock mechanism. I was a tough job but i did it. Now that the car is painted, i tried to re install the cylinder and can not attach the rod. Any help would be appreciated.
    Mel
  • Mel S.
    • August 31, 1992
    • 264
    Re: door lock cylinder
    Unfortunately there were no replies to my original post,so can anyone tell me how to get the rod off of the locking mechanism on the door lock.
    Thank You for any help
    Mel
      • 6948
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Ed I think the issue is that even with the lower clip removed, you can't swing the rod into position to the lock cylinder lever.
        I can't recall on C2's but on C1's that rod must be connected to the lock cylinder before installing the assembly into the door. You cant get the rod on or off the cylinder lever from inside the door. I think the same issue on C2's. Unless I'm thinking of the C1 door handle levers??
        Jack posted this photo in another thread but shows the rod with the special hooked end which attaches to the lock cylinder.
        • Mel S.
          • August 31, 1992
          • 264
          Thank You i will give it a try
          Mel
