68 Brake Caliper Rebuild - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Wish to rebuild/change my brake calipers to "O" ring style.
    Any suggestions for best vendor for rebuild kit?
    Thank you in advance,
    Kurt
  • Leif A.
    • August 31, 1997
    • 3626
    Re: 68 Brake Caliper Rebuild
    Lone Star Caliper
    Leif
    • Jim D.
      • 2883
      http://www.cssbinc.com/ They're the manufacturer, not a middle man.
        • 43213
        Kurt
        Kurt------
        Have the calipers been previously sleeved? If so, you can obtain an 0-ring conversion/rebuild kit from any of the vendors and do it yourself. If they have not been sleeved, you'll need to have that done first and, if so, you might as well have them converted at the same time.
        • Kurt B.
          • July 31, 1996
          • 971
          Joe,
          Calipers have been re-sleeved several years ago so I guess I can concert to the "O" rings myself
          Kurt
            • 43213
            Joe,
            Kurt
            Kurt------
            Yes, if they've been previously sleeved with high quality stainless sleeves, they should be fine.
            Something I forgot to mention: there are basically two types of o-ring pistons. One type uses no springs and the other uses springs like the original pistons. I recommend only the type that uses springs.
              • 11643
              Kurt------
              From what I've read and discussed with some of the brake companies the springs are optional, but not harmful or problematic.
              Like you, I'd install them anyway.
              • Dick W.
                • 10483
                I would agree with Leif and Jim. Both are reputable companies and do their own work.
                Dick Whittington
                • Kurt B.
                  • July 31, 1996
                  • 971
                  Thank you to everyone for the input.
                  Much appreciate it.
                  Kurt
                  • Jeff P.
                    • 799
                    Kurt I have used Lonestar many times. I had calipers rebuilt with O rings last year for my 68 project.
                    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                    2014 Arctic White Z51 Vert. (Wifes)
