requesting recommendation on plating chrome, B oxide, cad - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    I need to do some plating on my '70 Convertible prepping for Top Flight- who is good and priced reasonable
    ( and doesn't take 6 months ) for plating.
    Prefer So Calif but others OK bumpers, black oxide nuts and bolts, brake reservoir gold that sort of stuff
    THANKS
    Bob So Cal
    • 11643
    Re: requesting recomendation on plating chrome, B oxide, cad
    You can do black phosphate yourself; I did some Tuesday evening.
    Very few (if any) parts are actually black oxide, as it cost more than GM wanted to spend.
    • Bob B.
      • January 31, 2007
      • 524
      Excuse me, YES black oxide Patrick good to hear you the stickers are perfect THANKS Are you using the Eastwood black oxide kit ?
      Thanks Bob
      • Bob B.
        • January 31, 2007
        • 524
        BLACK PHOSPHATE !!!!!!!!!!!! its still early here in CA
          • 11643
          No, I use this:
          • Bob B.
            • January 31, 2007
            • 524
            OK bought some $41 including delivery also Eastwoods will give them a try THANKS AGAIN
            Bob
              • 11643
              The one I linked to is FAR better than the Eastwood Kit.
              I would not waste time or money with Eastwood.
              PH
              • Jeffrey S.
                • May 31, 1988
                • 1882
                I have used Shooters Solution for black phosphate for years with great results. It is available in 2 formulas- manganese phosphate and zinc phosphate- one is grayer than the other. I can't remember which but I'm sure a phone call to them will get you what you need. For black oxide I have always preferred Caswell.
                Jeff
                  • April 1, 2000
                  • 477
                  Curious about the process for those who have done this with good results as a DIY'er. Do you spray it on?, brush on?, immerse the item? Any other chemicals or heat or processing required? How durable?
                    • 11643
                    Jeff
                    Unfortunately Shooter's Solutions is no longer around.
                    I used Palmetto Enterprises before I used Shooter's Solutions, and went back to Palmetto at this time. It's easier now that they are on eBay (link provided earlier). The manganese is the darker phosphate, the zinc is the lighter.
                      • 11643
                      • Jeffrey S.
                        • May 31, 1988
                        • 1882
                        Patrick,
                        Thanks for letting me know that Shooters is no longer around. I haven't purchased for several years. When I need some more I will try your source.
                        Jeff
                        • Bob B.
                          • January 31, 2007
                          • 524
                          Anybody have anything good to say about chromers ? bumbers etc
                          Bob
                          • Gary J.
                            • April 1, 1980
                            • 1241
                            What about the cad plating?
                            • Bob B.
                              • January 31, 2007
                              • 524
                              Just a FYI I have been taking a good number of nuts/bolt and black phosphated items off both my 70's and 75 use paint remover to remove overspray IF needed and simple green if grease and soaking overnight in VAPO RUST A majority of the pieces are coming out pretty darn good AND ORIGINAL. doesn't LOOK "OVER RESTORED" not show car perfect pretty but very correct
                              old engine oil seems to preserve original black phosphate pretty well. Bob So Cal
                              Vapo rust is avail on amazon 5 gallon bucket
