Problem with carburetor linkage on 3 by 2 setup - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I am installing the carbs on my 69 427 435. I can't figure out how the linkage for the secondary carbs is supposed to attach to the primary carb. I have all the parts listed in the bolt kit, except for the teflon sleeve. But I can't see where this would matter. If I tighten the nut down so the linkage works the throttle plates on the end carbs, it binds up, and won't move. If I loosen the nut, it just slides in the slot on the center carb, and does not move the linkage. What am I not seeing here? Mark
  • Rich G.
    • August 31, 2002
    • 1397
    Re: Problem with carburetor linkage on 3 by 2 setup
    The linkage does not open the throttle. The vacuum pots on the other side of the carbs do that. The linkage is there to hold the end carbs closed until you apply WOT and then to close the carbs when you let off.
    Rich
    • Mark A.
      • February 1, 1996
      • 299
      Oh boy, do I feel stupid! I'm so used to mechanical secondaries, my mind was thinking that route. Thanks for taking the time to answer, and reset my brain. Mark
      • Rich G.
        • August 31, 2002
        • 1397
        • Danny P.
          • June 30, 2002
          • 341
          Hi Mark , here are some guide line you can follow
