62 ignition shielding - NCRS Discussion Boards
  • Carl R.
    • October 31, 2018
    • 63
    I would like to know what is the difference between the "60" and "62" Ignition Top Shield . I am seeing two different part numbers in all the parts books. Is it the tach cable location { generator vers distributor } or is there some thing else that is different about the set up. This will be for a non fuel injected engine, single four barrel carb.
  • Mike E.
    • February 28, 1975
    • 5138
    Re: 62 ignition shielding
    The depth of the front skirt and the notches/holes for the where it attaches in back to the shielding brackets come to mind immediately.
    • Carl R.
      • October 31, 2018
      • 63
      Thanks for the reply Mike, I will have to see if I can find some pictures of the two to compare the mounting.
