mildew on vinyl - NCRS Discussion Boards
mildew on vinyl
  • William F.
    • June 9, 2009
    • 1364
    mildew on vinyl
    I have white powdery substance, presumably mildew on vinvl seats in my '57 T Bird (forgive me, my only non Corvette car). I've tried the Concrobium that was previously suggest but to no lasting help. Car is in a garage. AC unit keeps things reasonably cool but I know compressor is bad and humidity stays relatively high. My '62 Corvette in same garage doesn't have this problem. What to do?
  • David R.
    • June 29, 2014
    • 183
    Re: mildew on vinyl
    Try white vinegar. I have used a 50/50 mix with water with good results, you may need to go stronger for stubborn residue but be sure to test it first in an inconspicuous area. The vinegar smell may linger for a day or two but it does go away. Good luck.
    • Ed S.
      • August 6, 2014
      • 1377
      Re: mildew on vinyl
      William, Get a box fan - they are not expensive, usually around $25 or less. Just let it run continuously - don't have to have it on the highest setting. Moving air is usually sufficient to prevent mold or mildew from establishing itself on surfaces. Do you ever see the large fans on golf course greens? They run them during damp weather to prevent mold from forming on the very expensive putting greens. Can't guarantee it will work for you but on the list of possible remedies, it is probably the least expensive. I keep a fan running under my '64 during the winter when it is damp in the garage - that will keep surface rust from forming.
      Ed
      • Steven B.
        • June 30, 1982
        • 4000
        Re: mildew on vinyl
        'Agree with David. White Vinegar. I have used it many times and it works well and a small amount of residue remaining on the surface (just don't rinse it off, but wipe dry) prevents growth for long time.
        • Richard F.
          • September 30, 1981
          • 498
          Re: mildew on vinyl
          Go to the experts, find a local marine supply store, they have a product by 3M, Marine Mildew Stain Remover & Mildew Block. There are other brand products 2 in 1, that are non aggressive and safe, follow up with your favorite not so shiny dressing.
          Rich
          • David R.
            • June 29, 2014
            • 183
            Re: mildew on vinyl
            Also good advice, a local marine supply store can be a great resource. Just check the contents of whatever they want to sell you, don't pay ten bucks for what's mostly a bottle of white vinegar.
            • Daniel S.
              • January 14, 2011
              • 309
              Re: mildew on vinyl
              I used Megs (see attached) on the interior of 4-Star Bowtie '67 L36 Convertible and it did a wonderful job of cleaning and preserving the interior. I'd consider that interior to have basic-to-light mildew and dust from sitting. I used a micro fiber towel with warm water and hand soup before the Megs. I also used it on the heavily soiled interior of our '62 big tank find and the interior was restored to near new on 1 pass. We will be using brushes and product for a second pass but for a spray product, results were fantastic.
              Dan
              • Mike K.
                • February 25, 2010
                • 68
                Re: mildew on vinyl
                I have used both the 3M Marine product and the Meguiars product and both work great. No wonder since 3M bought Meguiars a few years ago.
                • William F.
                  • June 9, 2009
                  • 1364
                  Re: mildew on vinyl
                  When I ask for help with a problem , I like to give a followup with hopes it will help others.
                  Didn't have much luck with the concorbium mildew "killer" product suggested in another thread about mildew and it Will stain, maybe pit brightwork.
                  White vinegar and box fan blowing through open doors seems to be working.
                  • Steven B.
                    • June 30, 1982
                    • 4000
                    Re: mildew on vinyl
                    Glad something worked! I've never used the fan. Good idea! Thanks
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Re: mildew on vinyl
                      William, you don't need AC, if you want to lower humidity you need a dehumidifier. Not really cheap to operate, but very effective if placed beside of the car.
                      Otherwise, do what I do. The white mildew will not penetrate or otherwise harm the vinyl. Just wipe it off.
                      Paul
                      • William F.
                        • June 9, 2009
                        • 1364
                        Re: mildew on vinyl
                        Will make ugly black stains if left.
                        • Jeff W.
                          • December 20, 2015
                          • 101
                          Re: mildew on vinyl
                          For those who get stains, I've had great success using Starbrite Mildew Stain Remover to get black stains our of or substantially lightened from white vinyl. Does not harm the surface. Walmart - Marine aisle.
                          • Ron G.
                            • December 1, 1984
                            • 865
                            Re: mildew on vinyl
                            I am quite confident that all the aforementioned methods to clean and prevent mildew work fine. However, I prefer using simple green with a 50/50 mix I am quite confident that all the aforementioned Waste to clean and prevent mildew work fine. However, I prefer using simple green with a 50/50 mix with hot water and maybe repeat applications with a cotton towel and he fine my alarm for us to get in all the nooks and crannies may just remove the existing mildew. Simple green is also environmental friendly and will not hurt the die color of the interior.
                            "SOLID LIFTERS MATTER"
