781 Horn relay question. - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Looking down at the relay with the mounting bracket above the relay and the connections below the cover where do the 3 wires attach? Tan to the left, red to the center and black to the righthand terminal??
    Thanks.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 781 Horn relay question.
    Anybody have any info?
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11334
      Bruce, On the relay cover is a "S" and a "H". S is "Switch". H is "Horn". The cover is made so it lines up to the terminals in either mounted position to the relay base with the closest S or H to the terminals.
      Tan(from horn button switch) goes to S, Black(to Horns) goes to H. So yes Tan to left and Black to right as pictured below. Red is the Bat feed to center terminal.
      Rich
