1966 427 425HP Engine compartment - NCRS Discussion Boards
  • Joe T.
    • February 25, 2018
    • 153
    I have looked at many 427 engine layouts and many are different. Per NCRS guidelines where should the correct hoses and clamps be located? As an example does the PVC hose go in front or back of the carburetor? Does the hose from the intake manifold to the power steering go under or over the throttle linkage and plug wires? Carburetor vacuum hose? Does the overflow from the radiator attach to the fan shroud? Please send pictures.. Thank you.
  • Marco H.
    • March 1, 2002
    • 218
    Re: 1966 427 425HP Engine compartment
    Joe,
    I suggest for you to get an 1966 AIM (Assembly Instruction Manual). Many of your questions are addressed in there. The PCV hose routing is described in the 1966 JG, Mech Section 6 Fuel System and Intake Manifold. The overflow hose is addressed in Chassis Section 5 Engine Cooling System. Hope this helps,
    Marco
    • Joe T.
      • February 25, 2018
      • 153
      Thanks Marco. I have one on order..
