C3 Power Steering - Is This Right??? - NCRS Discussion Boards
  • Don L.
    • August 31, 2005
    • 1005
    Hi all,
    Today, during my season shakedown, I noticed a wobbly power steering pulley. On disassembly, I found that the key slot was damaged (widened) to the point I can't use it anymore. I found a NOS pulley but I'm worried about the pump's shaft. There's what looks to be a chamfer on the shaft, just behind the key. See attached photo. Is the shaft supposed to be chamfered here or do I have a damaged shaft too?
    Any advice is appreciated. Thanks!
    Don Lowe
    NCRS #44382
    Carolinas Chapter
    • 43247
    Re: C3 Power Steering - Is This Right???
    Originally posted by Don Lowe (44382)
    Hi all,
    Don------
    Yes, that part of the shaft should be chamfered. However, I can't tell if yours is damaged.
    • Don L.
      • August 31, 2005
      • 1005
      Thanks for the quick reply, Joe!
      I just laid a scale parallel to the shaft, and I'd say the depth of the chamfer (laterally) is approx 3/64" to 1/32". Does this help you to know if I have damaged the shaft?
      I don't see any irregularities in the chamfer surface if that helps....
      Don Lowe
      NCRS #44382
      Carolinas Chapter
        • 43247
        Don------
        I think it's OK.
        • Gary J.
          • April 1, 1980
          • 1244
          If the shaft is damaged you can buy a just the pump only. You will to separate it from the housing and it should have a new keyway on the shaft. Would also a good time to insepect hoses also and replace.
          • Don L.
            • August 31, 2005
            • 1005
            Thanks Gary. It almost broke my heart but I replaced the ORIGINAL hoses from the pump to the control valve a couple winters ago as part of my power steering system restoration. I'm now afraid that I failed to properly torque the pulley and this is what caused my pulley failure. If the pulley is 1" deep, I'd say that I now have approx 1/8" of slot length on each end of the hole that are still at the proper width and in between, the once narrow slot is about four times wider than it's supposed to be. I'm thinking that the nut backed off, causing wobble, which in turn, ate the pulley up. Maybe?
            The good news is that I found what looks to be a nice NOS pulley and I can put it on and be done. What still concerns me is that I am fairly sure I torqued the pulley nut to spec when I put the system back together. Can you imagine how much more closely I'll be watching that pulley nut after I put it back together this time?
            Don Lowe
            NCRS #44382
            Carolinas Chapter
              • 15616
              Don
              I suggest that once you install the pulley and torque the nut you mark the nut and pulley with a witness mark that bridges both so that any movement between the nut and pulley will be obvious. I have used liquid white out in the past, but I just saw that Aircraft Spruce has a full set of colored pens designed just for this purpose. Their set contains more pens that both of us will use in our lifetimes. I think the white out will work fine for you and once you assure yourself there is no movement between the two items it can easily be removed.
                • 11666
                Don
                I've had a bear of a time removing white-out from some items.
                A nice Sharpie, silver being my preferred color, works well and can be removed often with isopropyl alcohol.
                  • 43247
                  Don------
                  The original nut was a self-locking type nut. The shaft pulley seating surface is slightly tapered which usually controls how far the pulley will seat on the shaft.
                  • Don L.
                    • August 31, 2005
                    • 1005
                    Don
                    Good idea. Thanks. I have access to some parts marking pens. I'll use one of them. Once I'm comfortable that it's tight, I'll wipe the ink/paint off with solvent..
                    Don Lowe
                    NCRS #44382
                    Carolinas Chapter
