Fan Clutch ID help - NCRS Discussion Boards
Fan Clutch ID help
  • Tom L.
    • October 17, 2006
    • 1439
    Fan Clutch ID help
    I bought a correctly dated tipped fan for my '72 and the pictured fan clutch was on it. It has a 5/8" pilot hole which indicates to me that it's a '70 or earlier clutch. There are no markings on it other than "EATON" stamped in the face. Is this a corvette part or just an over the counter replacement piece? Thanks!!
  • Mark E.
    • March 31, 1993
    • 4496
    Re: Fan Clutch ID help
    According to the JG, all '70-72 originally used Schwitzer clutches.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • David L.
      • July 31, 1980
      • 3310
      Tom,
      I have done a lot of research on fan clutches. These 7 1/4" dia. Eaton fan clutches were quite common on GM vehicles in the 1970's. Your fan clutch has the 2nd design face with the large "ears". The 1st design 7 1/4" Eaton fan clutches made in the late 1960's have a face with small "ears". I collected many fan clutches from salvage yards in the 1980's and 1990's. They usually are ink stamped on the front face with "EATON", a 2-letter code, and a date code.
      Example of an original fan clutch like yours from an early 1975 Chevrolet with 3991431 fan dated "C75" (March 1975): fan clutch stamped "EATON", "AK", and "E15FB" (E=May, 15 = 15th of month, F = 1975, and B is unknown).
      I also have a 7 1/4" Eaton fan clutch with the small "ears" from a 1971 Monte Carlo ink stamped EATON", "AG", and "E4B" which is also stamped "EATON" in very small letters.
      Enclosed is a photo of a 1969 Camaro 396 fan clutch stamped "EATON" and "CZ" (GM # 3946050) which I found on the web.
      Dave
      • James B.
        • February 28, 1985
        • 217
        Tom,
        My '72 LS-5 has a Schweitzer clutch.
        Jim
        • Tom L.
          • October 17, 2006
          • 1439
          Hey Jim, good to see you're still here checking things out. I knew that the clutch was incorrect for my '72. Just didn't want to toss a part that may be useful to someone. Guess this one will end up in the recycle bin. On a personal note, I've been working on the car. Will send an update soon. Have fun!!
            • January 31, 1988
            • 43191
            Tom------
            In addition to the 5/8" pilot, I assume the fan clutch hub bolt circle is 1-3/4" and the fan attachment bolt circle is 3". If so, this is the 1960-70 configuration. No 1960-70 Corvette ever originally used a fan clutch of the overall configuration you pictured.
            However, except for the aforementioned dimensions, this fan clutch is virtually identical in configuration to the late 70's Corvette fan clutch GM #460742. The latter fan clutch was also SERVICE for many Corvettes from 1971+.
