Car starts in neutral - NCRS Discussion Boards
  • Eddie R.
    • February 27, 2012
    • 22
    Hi. I have a 75 Corvette that I am restoring. The entire electrical system and battery has been replaced. The car wasn't running before that and since then only starts in neutral. This is my first C3 to restore. Is this normal or does something else need to be replaced on the car. I'm almost outside my warranty on the electrical system so I need to know if this is the problem or whether it is something else. Thanks Eddie Robin
  • Leif A.
    • August 31, 1997
    • 3645
    Re: Car starts in nuetral
    Automatic or manual transmission?? If an automatic, either the neutral safety switch is the issue or the linkage needs to be adjusted. By the way, what warranty are you speaking of??
    Leif
    • Eddie R.
      • February 27, 2012
      • 22
      Sorry. Car is an automatic. I have one year warranty on electrical system from service station that completed the work. Thanks for your help. Eddie
        • 43248
        Eddie------
        Do you mean it starts only in neutral and not also in park?
        • Stephen L.
          • May 31, 1984
          • 3162
          Re: Car starts in neutral
          Eddie, The same switch contacts are used as an interlock in both Park and Neutral positions. With that in mind you probably have an issue with the linkage actuating the switch and it needs adjustment.
