After 3 years of use, the repro tar top battery in my 1960 died and will not accept a charge. I know that it is built with an AGM-type battery inside the repro plastic shell.
Has anyone ever successfully opened up the repro battery case to access the AGM battery? I would like to replace the AGM battery. I don't know if the AGM battery was dropped in from the top and the top sealed to the shell or inserted from the bottom and a bottom plate sealed to the shell.
