E brake console - NCRS Discussion Boards
E brake console
  • Enzo C.
    • January 11, 2012
    • 533
    E brake console
    Does anyone have a pic of the screws for the emergency brake console... I bought an original console and the screw holes seem larger than my re pop console ?.
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
    • January 31, 1988
    • 43191
    Re: E brake console
    Enzo------
    The screws are #8 chome-finish sheet metal screws with a countersunk, oval head. However, there is an integral, chromed, cupped washer as part of the screw assembly. The assembly was GM #3839438 but I cannot find that it was ever available in SERVICE.
    The screw holes in the console are 5/16" OD at the outer surface. However, they are countersunk to accept the integral washer. Some reproductions may lack this feature.
    • Enzo C.
      • January 11, 2012
      • 533
      Re: E brake console
      Hi Joe, I appreciate the answer and pics... You are a sesspool of knowledge ... Thanks ver much
      Enzo Colosimo
      ENZ-Z06/67
      • Enzo C.
        • January 11, 2012
        • 533
        Re: E brake console
        Hi Joe, I am on the hunt for screws...mine are to small for the larger hole in the original console... Let me know . Thanks
        Enzo Colosimo
        ENZ-Z06/67
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11287
          Re: E brake console
          Enzo, If you cannot locate those special screw assemblies, you may be able to fabricate your own.
          Those conical washers are available separately. They were used on early midyear door panels. eg.....
          SF-534
          You might be able to use them with the oval Phillips head screws for the appearance of originals. eg...
          I-2714
          • Enzo C.
            • January 11, 2012
            • 533
            Re: E brake console
            Hi Richard,I appreciate your advice but I would rather have the correct screws for flight judging...being an interior judge myself I feel that the correct screw is deserved... Thanks
            Enzo Colosimo
            ENZ-Z06/67
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11287
              Re: E brake console
              I understand Enzo.....I hope you can find them. I know how hard it is to find some of the "little" things.
              Rich
              • Leif A.
                • August 31, 1997
                • 3599
                Re: E brake console
                Have you tried Rich Fortier??
                Leif
                • Enzo C.
                  • January 11, 2012
                  • 533
                  Re: E brake console
                  I have reached out to Rich Pasqualone... No reply
                  Enzo Colosimo
                  ENZ-Z06/67
