Vacuum Source - 1958 Dual Quad - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11339
    Re: Vacuum Source - 1958 Dual Quad
    Tom,
    That manifold more forward open threaded hole goes into the lifter valley, not the intake plenum area. Some manifolds were open, some closed. All I have ever seen were open though.
    I've used the NAPA IC12 coil with success many times.
    Rich
    ps You could make your own hollow stud if you have a good drill press or a friend with a Bridgeport.
    • Thomas H.
      • August 31, 2005
      • 1061
      Tom,
      Rich
      Rich,
      I have access to a milling machine at work. Should be first order of business on Monday............
      I put a different coil on and now I'm enjoying 8 to 10kV of secondary spark vs the 5 to 6 kV that I had with the new reproduction coil. Throttle response is much better.......
      I put a couple bolts in those holes anyway......... Didn't look like it went into the lifter valley as I could see aluminum on the other side. I'll try turning the garage lights off, shining a light down the carb and look to see if I can see the light through the hole.
      2007 Z06, Lemans Blue
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11339
        #18
        Reference CF thread about the "hole" from you know where.....
        C1 & C2 Corvettes - 58 - oil spitting from under distributor - While setting my timing and rev'ing up my engine at speeds of 3,000 RPMs...I noticed afterwards, that there was oil on top of my intake manifold. I put a piece of paper on top of it and could see oil spitting on it...coming from under the distributor plate...
        manifold backside/topside photos for reference. On the rear view you can see the hole heads into the lifter area. I don't know if some were blind or some were drilled. Jury is still out.
        • Thomas H.
          • August 31, 2005
          • 1061
          #19
          Rich,
          Got too excited thinking I found a vacuum leak and also a source of vacuum...... Double checking, yes as you state, the hole goes into the lifter valley. The "aluminum" I saw was the reflection of my flashlight off the iron block - using a bright white LED light.
          Got it running pretty well now. Hopefully I can get some time tomorrow afternoon to take it out for a spin.
          As usual, thanks to you and Frank for the help.
          Tom
