Lubing half-shaft U-joints in a '63 - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    OK - what's the secret ?
    My manual grease gun nipple just flat won't fit up in that tight space to do a decent job
  • Paul Y.
    • September 30, 1982
    • 570
    Re: Lubing half-shaft U-joints in a '63
    Check the location of the u joint. It might have been installed in the wrong position. Don't ask me how I know.
    It's a good life!
    • Gene M.
      • April 1, 1985
      • 4232
      Frank, I'm assuming you have grease fittings on the u joints. I suggest you use a needle fitting. It goes on your grease gun in place of the zerk snap on type. It has a soft tip that seals and retracts the grease fitting ball. Takes a bit of care to get good results. But once you use it it will become easy enough.
        • 6950
        Frank they make a couple of adapters for grease guns, one has a point to push the center of the fitting and another is a smaller angle head.
        • Frank D.
          • December 27, 2007
          • 2703
          OK I'll take another crack at it this weekend !
          • Douglas L.
            • May 8, 2015
            • 181
            I know on mine I cant grease the outer u-joints w/o jacking the car up a bit and playing around with the location of the grease zerk.
