Walnut shell or plastic media blasting - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1241
    Has anyone had their Corvette walnut shell or plastic media blasted? Don't want to use soda. Is the prefer method still paint stripper?
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Walnut shell or plastic media blasting
    I have seen more than a few plastic media blasted and as far as I,m concerned it ruined the fiberglass . I dont know about walnut shells . They both are great on metal cars but should not be used on fiberglass . Ask the blaster to show you a Corvette just as he is done blasting it .
    • Tracy C.
      • July 31, 2003
      • 2739
      Gary,
      Captain Lee's is my choice. No experience with walnut shells, but I've heard they leave behind a faint trace of oil from the walnuts.
      tc
      • Bill W.
        • March 1, 1980
        • 2000
        I like Captain Lees too .
        • Ronald L.
          • October 18, 2009
          • 3248
          the beads or shells abrade the glass, I just did one with co2, no trace left behind and the glass was as it came out of the mold.
          • Lawrence S.
            • April 1, 1993
            • 801
            Ronald can you expand on the process you used?
            • Ronald L.
              • October 18, 2009
              • 3248
              just like any other media lots of air and media, in this case it evaporates leaving not trace of what you've been up to.
              • Lawrence S.
                • April 1, 1993
                • 801
                You said you did one with CO2? Not sure what you mean...I will eventually paint my 67 L-36 Coupe and want to understand the right process.
                • Phillip M.
                  • September 30, 2006
                  • 100
                  This process, from what I understand, definitely is not do-it-yourself, and is more expensive than other types of media blasting. Process utilizes beads of dry ice to blast away crud. It is particularly effective against grease and oil as these contaminates are frozen and very effectively removed with little to no residue. This process requires specialized equipment, and from what I have seen, is part of a franchise type operation.
                  Phil M.
                  • Lawrence S.
                    • April 1, 1993
                    • 801
                    Thanks Phil
                    • Reggie M.
                      • April 1, 1981
                      • 47
                      I like the dry ice method. They come to you and there is no residue. They can also do the underside of the car.
                      • Lawrence S.
                        • April 1, 1993
                        • 801
                        Has anyone ever stripped undercoating from the underside of a metal car using this method? If so is it possible to just remove the undercoating and leave the gray primer?
                        Thanks guys,
                        Lawrence
                        • John P.
                          • December 1, 2001
                          • 1
                          I stripped my '64 with a product called PeelAway7- you brush a gel on heavy, cover it with their paper, and wait a few minutes' and just scrape the soft paint away. no bad smell, not corrsive, and it took it right down to the fibreglas. Not real fast but I was very pleased with it. I was advised against blasting because it gets into crevices and keeps coming out gradually.
