Wheel acceptability - NCRS Discussion Boards
Wheel acceptability
  • Jack J.
    • July 31, 2000
    • 640
    Wheel acceptability
    In short, depending on TIRE SIZE, will an Amerian mag wheel- 7 x 15, work on the rears of a 1964 Coupe without damaging the fender's inside glass lip? The fronts would have 6 x 15 wheels. Thank you , Jack J.
  • Leif A.
    • August 31, 1997
    • 3627
    Re: Wheel acceptability
    Jack,
    Width should not be a problem. Offset is where you could run into an issue.
    Leif
    • Jack J.
      • July 31, 2000
      • 640
      Leif, just what might work for the rears if I go with a radial down the road?
      • Leif A.
        • August 31, 1997
        • 3627
        Jack,
        I just installed a set of Diamond Back Michelin Defender redlines on the '67...size 215/70R15. Look and perform flawlessly.
        Leif
        • Michael J.
          • January 27, 2009
          • 7121
          I have American Mag 15X7s all around with 205X70R15 DB redline radials on my '64, no issues at all.
          • Jack J.
            • July 31, 2000
            • 640
            Just a note, too good of a deal to pass up. Mags and tires offered to me for $100.00 and since,just by coincidence, I had that amount with me I jumped on it. Right place, right time.
            • Leif A.
              • August 31, 1997
              • 3627
              Jack,
              Be sure to check the DOT numbers on those tires.
              Leif
              • Jack J.
                • July 31, 2000
                • 640
                Another footnote: the tires on the front 6x15's are P255/60 SR 15 and the tires on the rear 7x15's are P 215/70 R 15. All 4 tires are BF Goodrich. Again, primarily for the American mags. They came off a C1 car, year ??
                  Jack -
                  You do NOT want those fat 255/60's on the front and much narrower 215/70's on the rear - aside from looking really weird, you'll have handling problems. Also, the front tires are WAY mis-matched to the 15 x 6 wheels; 255/60 tires are designed for 7"-9" rims per B.F. Goodrich, and will look "pinched" and will have "crowned" tread surface on 6" rims.
                  • Jack J.
                    • July 31, 2000
                    • 640
                    ATTENTION-SENIOR MOMENT-JOHN H.- Front tires are 215/70 R 15's!! I really wanted the American mags for the price, the tires just happened to come along with the deal.
