73 Convertible Top Rear WS Question? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1695
    I'm having a problem with the rear weatherstrip that seals the top to the car. Each time that I put the top up after having it down, both corners of the weather strip come loose. Then I have to reinstall it using a small flat screwdriver (wrapped with vinyl tape) to get the WS back into the groove in the metal track. Is this a common issue? Should there be some WS adhesive applied? There is no sign of adhesive now. I believe there is a nylon type cord used on initial installation that you pull to get that "L" shaped edge on the WS to go into the "L" shaped metal track. Any helpful suggestions would be greatly appreciated. I'm worried that I'm going to start damaging the WS the more I do this. Thanks.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 73 Convertible Top Rear WS Question?
    If the nylon cord is not all the way to the end you need to add some.
    Lyle
    • Jimmy P.
      • June 24, 2014
      • 1695
      Thanks Lyle,
      That would be the problem. And where would one find some of that?
      Jimmy
      1973 Convertible
      L48,M20,N40
      • Bill L.
        • February 1, 2004
        • 1403
        Originally posted by Jimmy Patitucci (60161)
        Thanks Lyle,
        Try Al Knock.
        Bill
        • Jimmy P.
          • June 24, 2014
          • 1695
          Thanks Bill,
          ordered it, only a couple bucks.
          Jimmy
          1973 Convertible
          L48,M20,N40
