1970-1972 rear differential - NCRS Discussion Boards
  • Phil A.
    • April 30, 1982
    • 121
    Can you replace standard stub axels with heavy duty ones without making any other changes in a 70-72 Vette differential? Are there any other differences between a standard and heavy duty differential
  • Gary R.
    • April 1, 1989
    • 1799
    Re: 1970-1972 rear differential
    Hi Phil,
    Yes they are the same except for the yoke end holes.
    If you have excess endplay, over 050" for a stock posi setup, I would check to see where the play is. 70-72 original axles are reusable many times.
    My opinion is people give the HD axles more value then they are really worth. I have not seen one std or HD axle break at the yoke but plenty have twisted or snapped inboard. U-joints break, especially zerk joints and I have seen and broken them in both axle types. If yours are still good I wouldn't bother replacing them. If they are worn then chances are you're going to need more work. A stock build posi can still allow 020-030 endplay.
    • Michael W.
      • April 1, 1997
      • 4290
      Yes you can swap them but there's little advantage in doing so.
        • 43247
        Mike------
        There is one advantage. The hex bolts used with the caps are WAY easier to install and torque properly than the nuts on the u-bolts.
