68 Heat / AC Control Switch - NCRS Discussion Boards
  • Mike K.
    • February 25, 2010
    • 68
    I am in the process of rebuilding my Heat and AC Control unit on my '68.
    I am in need of a source to either purchase or rebuild the Control Switch
    as the picture attached. I would appreciate any help I could get here.
    Thanks Mike
    • 11698
    Re: 68 Heat / AC Control Switch
    Mike,
    Corvette Central manufactures kits to rebuild those units. They are not that tough to do if you have a bit of mechanical aptitude.
    Patrick
    • Mike K.
      • February 25, 2010
      • 68
      Patrick:
      Thanks for the reply.
      I have rebuilt the control housing and roller system. My real problem is the switch.
      I have cleaned it up, but the switch only works part of the time.
      From what I have come to learn, this was a one year only switch - '68. In '69 the
      subject switch was changed to a slide switch.
      Will keep looking.
      • Jim T.
        • March 1, 1993
        • 5351
        Mike what does the switch pictured control?
        • Steve G.
          • November 24, 2014
          • 411
          I have successfully repaired all kinds of switches like that. Take a good look at it and figure out how it was assembled. Bend back the crimped over tabs, pull it apart, wash the parts with aerosol brake cleaner. Fine Emory on all the contact points. Lube with a non conducting grease. Reassemble. There is nothing complex inside them.
          • Mike K.
            • February 25, 2010
            • 68
            Steve:
            THANK YOU SO VERY MUCH. This switch appears to supply the power, when activated, to the
            heater and ac compressor - if this is correct. I have seen other 68 climate control units and they
            all have the same switch.
            If my unit is incorrect, I am not sure where to turn now. Most all part companies, C.C and Paragon
            do not list anything for '68 - 69 and up.
