1954 Rear Convertible Latch Spring Question - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    I need a little help on how to correctly install the springs in the convertible top rear "sawtooth" latches. The latches had broken springs when I got them, so I purchased 2 new ones but not quite sure on how to install. Attached is a photo of what I have.
    I know that the little hook end on the spring fits into the small pinhole and the spring tab inside the spring fits in the slot of the latch shaft - a photo of an installed latch would be helpful....
    Any helpful advise or a photo would be appreciate.
    Thanks, John Lanning
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: 1954 Rear Convertible Latch Spring Question
    John, If you don't get a answer soon, I'm going to a friends house later today who has a '54 and will try to get a few pictures for you.
    I know nothing about the details of the '53-'55 tops, but ironically will be installing a rag on that '54 in the future. Then I'll have a little more knowledge in my head.
    Rich
    p.s. maybe like this?
    • John L.
      • February 1, 2005
      • 207
      Thank you very much Rich, I will give this a try since it seemed to be how it should work best. Hopefully if plans go as expected I will have the bodywork completed and maybe the top installed later this year. Right now trying to get the little pieces finished up over the winter.
      Good Luck?
      John Lanning
      54 #068
      • Chris S.
        • January 1, 2000
        • 1067
        John - I have a couple orig latches - I can take photos of.....
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • John L.
          • February 1, 2005
          • 207
          Thanks Chris ... my problem I believe is due to the difference in the replacement springs I purchased from CC which is larger than the origionals...
          • Chris S.
            • January 1, 2000
            • 1067
            There is a difference between the repro latches and the orig !!!!!!
