Trailing Arm Bushing Center Tube Flare - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Quick question.
    Should both sides of the flared center tube be flush with the washer(s)?
    I am thinking yes from reading previous threads.
    If that is the case is it fairly typical to slightly grind one side or the other to be flush?
    Bill
  • Joe R.
    • July 31, 1976
    • 4550
    Re: Trailing Arm Bushing Center Tube Flare
    Bill,
    Quick answer! The bushing will have to be compressed and both ends of the sleeve will have to be flared (one usually is already) as the assembly is compressed. The ends should be flush with the washers installed. You will need to borrow a staking tool or buy one from one of the big box Corvette parts suppliers.
    If you are doing this only once it will be cheaper to send the trailing arms out to someone like Bair's or Ikerds.
    JR
    • Bill L.
      • February 1, 2004
      • 1403
      Originally posted by Joe Ray (1011)
      Bill,
      JR
      Thanks.
      The bushings are installed and flared. The one side of the sleeve sticks out just slightly on one side of both bushings.
      Should both sides be flush with the washer?
      Bill
      • Gary R.
        • April 1, 1989
        • 1796
        Bill grind both sides flat. I do it on every arm I build, original or new.
        • Bill L.
          • February 1, 2004
          • 1403
          Thank you Gary. I saw an old trailing arm rebuild thread from you on another site with pics and it looked like exactly as you say.
          Bill
          • Gary R.
            • April 1, 1989
            • 1796
            The updated thread is on DC now. If you have any questions just let me know.
