'56 Clutch rod - NCRS Discussion Boards
'56 Clutch rod
  • Chuck B.
    • August 31, 1987
    • 122
    '56 Clutch rod
    I've found what I believe is a correct clutch rod for my '56 project, but am wondering if the spring clips on the fork are to hold the rod in place, or does something go through the fork into the rod. The AIM only shows the later style of clutch fork, so don't know if I'm missing something. Thanks Chuck Banks
  • Scott S.
    • March 1, 1979
    • 747
    Re: '56 Clutch rod
    Chuck, The assembly in your pictures is correct. The clips keep the rod from falling off the fork.
    Scott
    • Chuck B.
      • August 31, 1987
      • 122
      Re: '56 Clutch rod
      Thanks Scott. I guess the Gorilla spring will keep a constant pressure where the spherical end of the adjustment rod fits against the fork. Chuck
      • Jimmy B.
        • July 31, 1980
        • 584
        Re: '56 Clutch rod
        your missing the leather boot that covers up the hole where the fork goes into the bellhousing
        • Stuart F.
          • August 31, 1996
          • 4676
          Re: '56 Clutch rod
          Is it leather, or is it rubber as on later models like my 63? I had a 56 engine in 1957 as the second engine in my 50 Chevy coupe, but I don't recall a boot there. I was still experimenting with clutch linkages to marry the V8 throw out arm to the 50 peddle linkage. Never did quite solve that problem as I was using a B & B clutch with white springs.
          Stu Fox
          • Chuck B.
            • August 31, 1987
            • 122
            Re: '56 Clutch rod
            I have a leather boot, but the fifth edition of the 56-57 judging guide says that the standard shift transmissions didn't use a boot at the bellhousing. It seems like a boot would be a good idea. Chuck
            • Gary C.
              Administrator
              • October 1, 1982
              • 17659
              Re: '56 Clutch rod
              Chuck,
              No leather boot listed in the 1956 Bill of Materials. No original 3 or 4 speeds 1957 that I've tracked had a leather boot clutch fork cover.
              3728567 appears to be the part number for the early design clutch fork retaining rod.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: '56 Clutch rod
                FWIW, I looked in the DocRebuild catalog and I see they show a Suede Leather Fork Boot for 56 through 1960. it says it includes a wire retainer to mount in a cast iron bell housing. It then lists a rubber boot for 60 through 1962 models with aluminum bell housings.
                They take great pride in marketing accurate reproduction parts, and I have found this to be true for the items I have bought there. Others may have a different opinion, specially if they had trouble communicating with them. I have not.
                Stu Fox
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17659
                  Re: '56 Clutch rod
                  Stu,
                  1956 & 1957 Passenger cars did, 1956 & 1957 Corvettes did not.
                  Gary
                  NCRS Texas Chapter
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    Re: '56 Clutch rod
                    Ironically, I owned several tri-fives with manual transmissions, but never saw any boots on the clutch forks until I bought my 63 Vette. Go figure.
                    Stu Fox
                    • Mike E.
                      • February 28, 1975
                      • 5138
                      Re: '56 Clutch rod
                      61-62 Corvettes never came with a clutch fork boot from the factory. Multiple vendors have been selling them for several decades. That still hasn't made them correct.
                      • Steven B.
                        • June 30, 1982
                        • 3989
                        Re: '56 Clutch rod
                        Like Gary the original cars I have seen did not have a boot. My original Dec 1956 built '57 I bought in Nov '64 did not have a boot. Steve
                          Re: '56 Clutch rod
                          No C-1 EVER had a leather clutch fork boot (or any kind of clutch fork boot), but the vendors love to sell that leather one.
                          • Edward M.
                            • November 1, 1985
                            • 1916
                            Re: '56 Clutch rod
                            I disassembled an original early 56 passenger car with a 265, 3 speed trans. It had the leather boot, which was in pretty bad shape. I have never seen a boot of a 56 Corvette.
                            • David B.
                              • March 1, 1980
                              • 689
                              Re: '56 Clutch rod
                              Sorry, Jimmy my boy! you got caught on this one. No leather or rubber boot on the 56,57 Corvette.
                              As for the rod, It appears # 3726733 had not yet been assigned yet thru in 56,57. Probably a slight change involved using this # If we are talking the same part. Might be interesting to see why changed.
                              Again, if we are talking the same part, #3726733 is listed for '56 corv only
                              5 61/64 O L w 3/8 - 16 thread. Would measure etc. to determine if correct.
