1969 Frame Off Restoration - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 256
    I am doing a frame off on a 1969 convertible. Getting ready to refinish the differential casing and have a question on the finish on the 8 bolts that attach the rear cover to the differential. I can not tell if the bolts are natural or blackened? Any information?Steve
    • 3415
    Re: 1969 Frame Off Restoration
    Hi Steve,
    The bolts on my 71 differential casing showed the remains of a dark finish.
    Can't say if it was black oxide or manganese phosphate.
    I redid them in the manganese phosphate.
    The lock washers are quite thick compared to regular lock washers of that size and had a dark finish too.
    • Steve M.
      • January 1, 2006
      • 256
      Thanks for the reply.Steve
        • 43219
        Steve-------
        The bolts, GM #3843384, were a phosphate-organic finish. These appear like a "slightly shiny" or "lightly oiled" finish. They appear slightly brown. It's a virtually impossible finish to re-create. However, if you use gray phosphate finished bolts, I don't think anyone will know the difference.
          • 43219
          Steve-------
          All------
          I can't edit the post now, but I was incorrect on the GM part number for the differential cover bolts. The 3843384 are the same thread size and length but they have a short, unthreaded shank and are SAE grade 8. The cover bolts are full thread and SAE grade 5. I believe that they were both of the same phosphate-organic finish, though.
